Retired_Member
Jan 24, 2016FVS318N WAN to LAN throughput and performance
Hi, Recently upgraded my DSL connection 8M/1M to Cable 130M/30M. I changed from using PPoE to direct connection and modified the MTU size back to the default 1500 as per the provider recommendati...
DaneA
Jun 08, 2016NETGEAR Employee Retired
Hi 2M,
Welcome to the community! :)
Kindly answer the questions below:
a. How is everything connected?
b. Did you also change your internet connection from DSL to cable?
c. What is the current firmware version of your FVS318N?
d. What troubleshooting steps have you done so far?
I look forward to your response.
DaneA
NETGEAR Community Team
2M
Jun 08, 2016Initiate
Hey DaneA,
a. How is everything connected? WAN interface from our ISP, LAN to 2 gigabit switches. have aproximately 25 devices connected.
b. Did you also change your internet connection from DSL to cable? negative, never was DSL, is static business class from ISP cable company 100/75 is what we are paying for.
c. What is the current firmware version of your FVS318N? 4.3.3-6, i know there is a later version, i will be loading it up tonight after work hours.
d. What troubleshooting steps have you done so far? when i plug a pc directly into the cable modem/router, i get the speeds purchsed so not an ISP issue. when I test going through the Netgear, only getting around 50/32. i've tried being plugged into the switch and also directly into the Netgear, with same 50/32 results.
any ideas is appreciated.
Phil
- DaneAJun 09, 2016NETGEAR Employee Retired
2M,
Since you plan to update the firmware of your FVS318N to v4.3.3-8, be sure to perform a factory reset on the FVS318N after successfully upgrading the firmware then reconfigure it from scratch. Afterwards, observe if same problem occurs.
Retired_Member,
Were you able to open an online case with NETGEAR Support and report about your concern for further assistance?
DaneA
- Retired_MemberJun 10, 2016
DaneA wrote:2M,
Retired_Member,
No I was unable to do this because I cannot transfer the 2nd hand FVS318N serial number to my account :(
Why do we need to reconfigure the entire unuit from scratch? Isn't the purpose of the firmware upgrade to deal with the current configu or at least accept the configuration backup file?
It's like every time a patch is release I have reconfigure my preferences in Windows....
- 2MTechJun 10, 2016Aspirant
after firmware update, i amnow getting 100/32, better.... but now the upload speed decreased
2MTech wrote:after firmware update, i amnow getting 100/32, better.... but now the upload speed decreased
After reboot prior to upgrade I'm back at 191/32 but this decreased overtime. Will upgrade the firmware now and see how long this speed will remain. No mention of a fix related to the memory leak in the release notes.
- DaneAJun 12, 2016NETGEAR Employee Retired
Retired_Member,
A factory reset is recommended in order to have a clean setup on the VPN firewall using the latest version of the firmware.
If ever the same problem occurs after you have upgraded the firmware to the latest version, I suggest you to open an online case with NETGEAR Support at anytime and report about your concern for further assistance.
DaneA
- Retired_MemberJun 13, 2016
DaneA wrote:Retired_Member,
DaneA
After upgrade the unit held 1 day of 191/30 performance, but has now dropped to 56/30
Logs are still showing signs of memory leaks. The logs are not consistent, with entries not appearing chronologically in the viewer:
Mon Jun 13 06:34:57 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data
Mon Jun 13 06:34:52 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:34:47 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:34:42 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:34:37 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:34:32 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:34:27 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:34:26 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data
Mon Jun 13 06:34:21 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:34:16 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:34:11 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:34:06 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:33:56 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:33:51 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:33:46 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:33:36 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:33:26 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:33:16 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:33:11 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:33:06 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:33:01 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:32:31 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:32:01 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:31:31 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:31:01 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:30:31 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:30:01 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:29:31 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:29:01 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:28:56 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:28:36 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:28:06 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:27:36 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:27:05 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:26:35 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:26:05 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:26:00 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:25:35 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:25:30 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:25:25 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:25:20 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:25:20 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data[snippet]
Mon Jun 13 06:25:10 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data
Mon Jun 13 06:25:05 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 06:21:31 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] key
Mon Jun 13 06:21:31 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] installing key to index 1
Mon Jun 13 06:21:31 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] GK state changed from SetKeys to SetKeysDone
Mon Jun 13 06:21:30 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] PTK GK state changed from GkeyEstablished to Idle
Mon Jun 13 06:21:30 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_SET_PARAM(52)
Mon Jun 13 06:21:30 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] (node=38:f2:3e:90:59:f4) setting portSecure to val = 1
Mon Jun 13 06:21:30 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] PTK GK state changed from GkeyNegotiating to GkeyEstablished
Mon Jun 13 06:21:30 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] processing group key message 2
Mon Jun 13 06:21:30 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] eapolRecvAuthKeyMsg: received key message
Mon Jun 13 06:21:30 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] Recvied DOT11_EAPOL_KEYMSG
Mon Jun 13 06:21:30 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][PNAC_USR] from pnacPDUProcess: received PNAC_EAPOL_KEY_PACKET
Mon Jun 13 06:21:30 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][PNAC_USR] from pnacRecvMapi: pkt body len = 113, pktType = 3[snippet]
Mon Jun 13 05:15:16 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] installing key to index 2
Mon Jun 13 05:15:16 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] GK state changed from SetKeys to SetKeysDone
Mon Jun 13 05:15:15 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] key
Mon Jun 13 05:15:15 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] installing key to index 2
Mon Jun 13 05:15:15 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] GK state changed from SetKeys to SetKeysDone
Mon Jun 13 05:15:14 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] GK state changed from SetKeysDone to SetKeys
Mon Jun 13 04:09:28 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] key
Mon Jun 13 04:09:28 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] installing key to index 1
Mon Jun 13 04:09:28 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] GK state changed from SetKeys to SetKeysDone
Mon Jun 13 04:09:28 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] PTK GK state changed from GkeyEstablished to Idle
Mon Jun 13 18:36:49 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 18:36:44 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 18:36:34 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 18:36:28 2016(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data <4
Mon Jun 13 18:36:26 2016(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] keyStill some work to be done for the next firmware...
- DaneAJun 14, 2016NETGEAR Employee Retired
Retired_Member,
I'm afraid that we could not yet conclude if its really a memory leak unless the logs has been analyzed by the engineering team. Thus, opening an online case with NETGEAR Support is advisable.
DaneA
- Retired_MemberJun 15, 2016
DaneA
Hi Danea, I seem to be unable to register a case with Online support for this, please advise on how to proceed.
Regards!
- DaneAJun 16, 2016NETGEAR Employee Retired
Hi noibla,
Have you clicked on "Get help on my NETGEAR product" then proceed with the online instructions? Kindly refer to the image below:
DaneA
NETGEAR Community Team - DaneAJun 20, 2016NETGEAR Employee Retired
Hi noibla,
Were you able to open an online case?
DaneA
- Retired_MemberOct 02, 2016
I'm very disappointed in the support from Netgear. I have strripped down the router configuration so that minimal logging is enabled and still the loggin seems to be garbled and overrunning. With the Latest software release form august 2016 nothing has changed.
I reboot the router once in a whil and then I'm able to get the speed that I have with my ISP (190 Mbps down and 30 Mbps up). but after a while this drops back to 30/30.
Very disappointed with a product that has a datasheet that claims 250 Mbps throughput.
- DaneAOct 03, 2016NETGEAR Employee Retired
Hi noibla,
I believe that the NETGEAR Support expert assigned on your case # 27489789 has already responded to you and is asking for the serial number of your FVS318N as well for it to be registered. Kindly reply into it and keep us posted about the progress of your online case.
DaneA
- SamirDOct 03, 2016Prodigy
This is quite interesting. I've never been able to get any of my fvs318n's above 60 something download on the wan. I'll be curious to see the solution to this riddle.
- Retired_MemberNov 23, 2016
Hi All,
The support case had led to the unit being replaced but something else happened too. 2 new firmware releases took place. 4.3.4.1 and 4.3.4.2. The 4.3.4.1 release note have the following comments:
Bug Fixes:
- Fixed the issue where the logs are not displayed properly in the GUI and on Syslog server.
- Fixed the issue where the firewall logs contain incomplete logs messages.
The unit was replaced under RMA afer good response from the Netgear team. I returned my old unit and the new unit came in a box where the specs still referred to the old datasheet (95 Mbps WAN-LAN).
Both units (witn 4.3.4.1 software ran fine with the 190 Mbps consistent download. I also further looked into differences in the hardware platform used (Cavium CNS3411 Network processor). Both units were the same.
To summarise: it was likely a memory leak issue in the prior firmware in relation to the log messages prior to firmware 4.3.4.1
- SamirDNov 23, 2016Prodigy
Thank you for posting a followup to the issue!
I will definitely have to try the 4.3.4.1 and 4.3.4.2 releases and see if my WAN speeds break the 60Mbps barrier. I actually have a much faster connection (150/25) at one of my endpoints that's being limited to 60Mbps, so it will be a worthwhile upgrade if it works for me as well.
- SamirDFeb 11, 2017Prodigy
So I finally had a need to try the upgraded firmware v4.3.4-1, and I'm very happy to say initial results look great! I saw 170+ down, which I had to check several times just to make sure I wasn't doing something wrong. I'm going to let it sit overnight and let's see if the throughput reduces. I'll be a happy camper if it doesn't as I was going to replace one of these in the field because it wasn't able to handle the full bandwidth of 150/25.
- SamirDFeb 12, 2017Prodigy
As an update to this, it's 24hrs later and a speedtest was still 170+ and everything working smoothly.
I have set up an iperf test that will pass a lot of traffic through the router for the next 24hrs. This will be my final test, and if it passes, it's time to upgrade some of our production routers firmwares. :)
- SamirDFeb 14, 2017Prodigy
Well 2 days and half a million packets later, it's still running at top speed. Looks like this firmware definitely solves any speed issues. I'll be deploying it on our other FVS318Ns. :)
I'm really glad this worked as I was about to replace a 318N in a location where the bandwidth increased to 150/25.
- rlcarperFeb 19, 2017Tutor
No luck here,
Netgear support are still providing support on this case, but it seems that even more items are being disabled. I had rebuilt my configu from scratch after the recent firmware upgrade. I find it quite troublesome to rebuilt a complex configuration entirely from scratch with every firmware upgrade. Neatgear should really have a solution for this.
I'm considering moving over to Ubiquiti...
- SamirDFeb 19, 2017Prodigy
Every smb router has to have its config rebuilt, not just Netgear. And the edgerouters are even worse with the entire config command line xml if it's complicated. And you'll have to set it up every time there's a firmware update as well.
Programming is just not quality controlled enough to migrate from one firmware to another without configuration rebuilds/glitches unless you're paying thousands of dollars a year for support (ie high end enterprise gear).
- rlcarperFeb 24, 2017Tutor
Hio SamirD. it seemed taht bandwidt control driver on my ethernet card was disrupting my recent tests. Rebooted the FVS318N at noon today and so far still 190 Mbps / 30 Mbps. fingers crossed...
- SamirDFeb 24, 2017Prodigy
Awesome! If you see any more problems, be sure to try a different system if you can. It's helped me diagnose bandwidth issues before. But I hope you have just smooth sailing from here!
