lbrunetti
Nov 17, 2011Aspirant
FVS336G - multi homing configuration problem
Hi, I have two different networks: 192.168.22.0/24 172.16.248.128/25 FVS336G firewall's IP is 192.168.22.1. This is also the default network gateway. FVS336G multi homing settings are: IP: 1...
jmizoguchi
Nov 17, 2011Virtuoso
Add Secondary LAN IP Address
To add a secondary LAN IP address, type in the IP Address and the Subnet Mask in the respective text fields and click Add.
Note: Additional IP addresses cannot be configured in the DHCP server. The hosts on the secondary subnets must be manually configured with the IP addresses, gateway IP and DNS server IPs
try gateway with 192.168.22.1
