akatato
May 01, 2017Follower
FVS336G and DMZ port
Hi!
On the FVS336G there are 4 lan ports, one of these is marked as DMZ port. This means that, if the firewall is enabled, by default this port is in DMZ lan and the other 3 ports are in internal lan?
- DaneANETGEAR Employee Retired
Hi akatato,
Welcome to the community! :)
By default the DMZ port is disabled on the FVS336G and this means that you can use this port as part of the local area network. As reference, kindly read pages 141-145 of the FVS336Gv3 reference manual here.
DaneA
NETGEAR Community Team
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
