train_wreck
May 27, 2016Luminary
FVS336G changes WAN MAC address based on connectivity - how to disable this?
There is a highly annoying feature of this router I would like to disable. When the router loses internet connectivity, it appears to change its WAN MAC address to a "dummy" address of "00:de:ad:xx:x...
train_wreck
May 30, 2016Luminary
One thing I did find while browsing around the CLI: There are references to the de:ad address on the loopback interface. Here is the output of "util routing_table_ipv6":
::1/128 :: U 0 0 1 lo fc00::/128 :: U 0 0 2 lo fc00::1/128 :: U 0 0 1 lo fe80::/128 :: U 0 0 2 lo fe80::/128 :: U 0 0 2 lo fe80::/128 :: U 0 0 2 lo fe80::2de:adff:fe10:7500/128 :: U 0 0 1 lo fe80::2de:adff:fe10:7501/128 :: U 0 0 1 lo
Note the IPv6 loopback has numerous addresses, one of which has the exact same value as the MAC address listed in the modem screenshot (00:de:ad:10:75:00). As to why a loopback address on the FVS is showing up in the ARP tables of other devices..... no idea.
train_wreck
May 31, 2016Luminary
Another development: with port mirroring enabled, a packat capture on the mirrored port shows the following IPv6 broadcast packets send from the FVS:
02:00:42.820407 de:ad:de:ad:de:af > 33:33:00:00:00:02, IPv6, length 70: fe80::2de:adff:fe10:7500 > ff02::2: ICMP6, router solicitation, length 16 02:00:46.820232 de:ad:de:ad:de:af > 33:33:00:00:00:02, IPv6, length 70: fe80::2de:adff:fe10:7500 > ff02::2: ICMP6, router solicitation, length 16 02:00:50.820144 de:ad:de:ad:de:af > 33:33:00:00:00:02, IPv6, length 70: fe80::2de:adff:fe10:7500 > ff02::2: ICMP6, router solicitation, length 16
