jrpsupport
Mar 08, 2012Tutor
FVS336G Firmware Version: 3.0.3-17
I have this Router attached to a 200Mb WAN connection. I know the Netgear FVS336G is only capable of a Max of 60Mb incoming throughput on the WAN ports. But we are only getting 6Mb-11Mb incoming a...
WestGigFibre1
Jan 12, 2014Novice
adit wrote: Upgrade the firmware, follow my procedure.
Makes no difference doing it my way or your way except that I waste a lot more time doing it your way. FYI, followed your method to the T with two different FVS336G v2 and got the same low speeds that we saw upgrading the firmware the 'usual' way. The firmware IS the problem and each new upgrade slows the FVS336G down more each time.
