jrpsupport
Mar 08, 2012Tutor
FVS336G Firmware Version: 3.0.3-17
I have this Router attached to a 200Mb WAN connection. I know the Netgear FVS336G is only capable of a Max of 60Mb incoming throughput on the WAN ports. But we are only getting 6Mb-11Mb incoming a...
Daedalus01
Jan 15, 2014Aspirant
So since I didn't say that some score right near the advertised speed or over it that I am stuffed? If I were to take you literal in what you posted, the fact that you can see speeds of 79-91Mbps when you have a 25Mbps connection is brilliant. Take it and run. Wait, Did you mean that you have 50Mbps at your office? You only said the area so I'm not sure. So no, it does not blow my theory out of the water as you put it. If you're so unhappy with Netgear, go to Cisco,Juniper,Fortinet,etc. No one is forcing you to use a Netgear at your office ( hell, I don't). Buy a different router and see if the speed increases. If it does, shelve the 336G and keep it as a spare. Or sell it and have a few pints. As for the SRX5308 don't believe everything you read. IMHO its nothing more than a shiny paperweight. I have a seen so many issues with both the hardware and the firmware.
