jrpsupport
Mar 08, 2012Tutor
FVS336G Firmware Version: 3.0.3-17
I have this Router attached to a 200Mb WAN connection. I know the Netgear FVS336G is only capable of a Max of 60Mb incoming throughput on the WAN ports. But we are only getting 6Mb-11Mb incoming a...
WestGigFibre1
Jan 27, 2014Novice
SamirD wrote: This isn't an issue with just Netgear equipment--Cisco's rv042G has had problems breaking the 100Mbs mark without an elusive beta firmware for years now.
It's just the half-working nature of equipment in this price range. If you want something real and reliable, you have to be ready to spend 2-10x the price of these units.
What are you trying to say? It doesn't really make sense. If the original FVS336G v1/v2 firmware did work and each new update has slowed down the hardware, how is that the same as what you are comparing?
What is the point of listing specs for a product?
When you purchase a product, do you consider the specs when making your decision?
Why after more than two years has a solution not been made?
Why is a product that has had known short comings to its rated specs for over two years still being sold with specs it can not meet?
Why are the level 1, level 2 and level 3 techs at netgear claiming that they will looking into the problem now that they have been made aware of it as if they never knew the problem existed?
I would think this is very misleading and not fair since it starts right from the pre-sales right through to warranty and tech support.
Is it too much to ask for a solution that actually addresses the problem?
