jrpsupport
Mar 08, 2012Tutor
FVS336G Firmware Version: 3.0.3-17
I have this Router attached to a 200Mb WAN connection. I know the Netgear FVS336G is only capable of a Max of 60Mb incoming throughput on the WAN ports. But we are only getting 6Mb-11Mb incoming a...
WestGigFibre1
Feb 05, 2014Novice
Daedalus01 wrote: All good questions. Why don't you ask Netgear and see what they say. I'm curious as to what the response would be. Since I haven't had any bad experiences other than a FVS114 ( worthless) and a GS724 ver1 dieing, I guess I've been lucky. I know there are a few Netgear employees on here, although most are end-users. Even asking directly you might not get an answer.
Netgear has no real answer to any of the questions I ask. Sure there are a few level 2 and 3 techs which will remain nameless for their honesty that have indicated that Netgear has known of the problems with many product short comings including the very low WAN to LAN speeds of the FVS336G v1 and v2 with firmware updates but most likely won't address them.
I couldn't even get a straight answer from them on what (Netgear product) would preform as the FVS336G was spec'd at.
Only solution that Netgear has is to RMA the unit which after three attempts has not solved the problem. When I asked them "so what now?" they had no answer other than to RMA it again.
