woodd
Aug 31, 2015Aspirant
FVS336G How do I change the certificate presented from 192.168.1.1 (Default admin)
I have the FVS336G installed to load balance between two internet providers (small office) The admin page is SSL secured with a self signed NetGear CA certificate - After I add this certificate into...
- Sep 03, 2015
Hi woodd,
The FVS336Gv1 does not have a console port whereas both the FVS336Gv2 and FVS336Gv3 does have a console port. However, there is still no option to update the admin certificate nor swap out the certificate file via a console connection.
As per the CLI reference manual, it says on page 6: "You cannot generate and upload a certificate through the CLI..." You may access the CLI reference manual here.
DaneA
Netgear Community Team
josephinelcajon
Jan 28, 2024Tutor
I have a similar problem; I cannot load the sign in page at all 192.168.1.1 returns with a blank page "This connection for this site is not secure" and "192.168.1.1 uses an unsupported protocol" then "ERR_SSL_VERSION_OR_CIPHER_MISMATCH" Tried every browers I can think of tried turning off cookies cash even three different computers and nothing!
ErwinL
Jan 30, 2024NETGEAR Moderator
Hello@josephinelcajon
Unfortunately Netgear has ended the life of router FVS336G serval years ago. There are no longer firmware updates for it to support new versions of browsers protocol. When your browser’s TLS and SSL settings don’t align with what the server expects, you’ll see that error. But if you wish to have access to it's user interface there is a way but would require you to change configurations on browser. I found one example that might help is from the link below:
https://www.designbombs.com/how-to-fix-the-ssl_error_no_cypher_overlap-in-firefox/
Have a lovely day,
Erwin
Netgear Team
