woodd
Aug 31, 2015Aspirant
FVS336G How do I change the certificate presented from 192.168.1.1 (Default admin)
I have the FVS336G installed to load balance between two internet providers (small office) The admin page is SSL secured with a self signed NetGear CA certificate - After I add this certificate into...
- Sep 03, 2015
Hi woodd,
The FVS336Gv1 does not have a console port whereas both the FVS336Gv2 and FVS336Gv3 does have a console port. However, there is still no option to update the admin certificate nor swap out the certificate file via a console connection.
As per the CLI reference manual, it says on page 6: "You cannot generate and upload a certificate through the CLI..." You may access the CLI reference manual here.
DaneA
Netgear Community Team
josephinelcajon
Jan 28, 2024Tutor
I have a similar problem; I cannot load the sign in page at all 192.168.1.1 returns with a blank page "This connection for this site is not secure" and "192.168.1.1 uses an unsupported protocol" then "ERR_SSL_VERSION_OR_CIPHER_MISMATCH" Tried every browers I can think of tried turning off cookies cash even three different computers and nothing!
ErwinL
Feb 06, 2024NETGEAR Moderator
Hello@josephinelcajon
Was your problem resolved? In this case could you give us a feedback on the situation and accept the post as a solution to make it more visible to other users?
Thanks in advance! 🙂
Have a lovely day,
Erwin
Netgear Team
