Hogskin44
Dec 11, 2015Follower
FVS336G Speed question
I have a home network using an FVS336V router, and have several computers used for a home-based business. I needed more speed, so I upgraded two of the computers, replacing the hard drives with SSD's. The speed did not improve when data had to pass through the network. So I did the following test:
- Testing with folder containing 4914 files, using 188 MB on disk.
- Copy folder FROM computer 1 TO computer 1, takes 3 seconds
- Copy folder FROM computer 2 TO computer 2, takes 3 seconds
- Copy folder FROM computer 1 TO computer 2, takes 90 seconds
- Copy folder FROM computer 2 TO computer 1, takes 90 seconds
There was virtually on other traffic on the network during this test. The amount of data (< 2 GBits) should not be taking that long to pass through network.
Can anyone give me an explanation or advice on how to improve on this performance?
Thanks!!
John
1 Reply
- DaneANETGEAR Employee Retired
Hi Hogskin44,
Welcome to the community! :)
Let us isolate the problem. Kindly answer the questions below:
a. Is the LAN adapter of both of your computers capable of 1Gbps?
b. Are you using a CAT5e or CAT6 ethernet cables?
c. Are the PCs directly connected to the FVS336G?
d. How is everything connected on your home network? Kindly post a screenshot of your detailed network diagram.
I look forward to your response.
DaneA
NETGEAR Community Team
