Retired_Member
Sep 04, 2015FVS336G SSL VPN login loop
I have the domain and user configured. When I login to test, I'm prompted for to change the password. I change it, it logs me out and when I log back in, I'm prompted to change the password again. ...
- Retired_MemberOct 07, 2015
It appears that in 64-bit Windows 10, the SSL VPN will not work regardless of the browser. I've tried running IE-11 as 32-bit and 64-bit, and it gives me the same results: it will not install the virtual interface. There isn't a way to choose "Compatibility" in Windows 10 for IE-11. If there were, I would set it to Windows XP SP3 which I know works.
Windows 10 32-bit version, works fine when I install the tunnel using Firefox running "Compatibility" set to Windows XP SP3.
JohnRo
Sep 05, 2015NETGEAR Employee Retired
Hello BrunoCorazon,
I'll need to get some information for me to be able to help you isolate your issue. I have listed them below:
1. Firmware version of the firewall.
2. Browser(s) used.
3. After changing the password, do you get the notification like "operation suceeded"?
I'll look forward to your response.
Thanks,
Retired_Member
Sep 10, 2015Thanks.
1- I will have to get back to you on this one.
2- Firefox, Chrome, Opera, MS-Edge. Same results for each.
3- Yes, I get a message stateing that the operation succeeded, so I try to login with the new password and get prompted to change the password.
