Retired_Member
Sep 04, 2015FVS336G SSL VPN login loop
I have the domain and user configured. When I login to test, I'm prompted for to change the password. I change it, it logs me out and when I log back in, I'm prompted to change the password again. ...
- Retired_MemberOct 07, 2015
It appears that in 64-bit Windows 10, the SSL VPN will not work regardless of the browser. I've tried running IE-11 as 32-bit and 64-bit, and it gives me the same results: it will not install the virtual interface. There isn't a way to choose "Compatibility" in Windows 10 for IE-11. If there were, I would set it to Windows XP SP3 which I know works.
Windows 10 32-bit version, works fine when I install the tunnel using Firefox running "Compatibility" set to Windows XP SP3.
JohnRo
Oct 06, 2015NETGEAR Employee Retired
Hello BrunoCorazon,
I'm glad that the issue was with only the browser combination, I was kind of thinking it was a bigger issue, and was looking far from the browsers.
Thanks,
Retired_Member
Oct 07, 2015It appears that in 64-bit Windows 10, the SSL VPN will not work regardless of the browser. I've tried running IE-11 as 32-bit and 64-bit, and it gives me the same results: it will not install the virtual interface. There isn't a way to choose "Compatibility" in Windows 10 for IE-11. If there were, I would set it to Windows XP SP3 which I know works.
