gheatly1's avatar
gheatly1
FVS336Gv2 3.x.x-x configuration on 4.x.x.x platform
After upgrading firmware from 3.x.x-x (platform 1.0 base) to 4.x.x.x (platform 2.0 base) on an FVS336Gv2 firewall, can the former 3.x.x.x configuration be loaded??
1 Reply
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi gheatly1,
    Welcome to our community! :)
    Unfortunately, we cannot use the configuration file from the 3.x.x.x version as they are now in a different family version. You may still use it within the 3.x.x.x family, but not in 4.x.x.x. I suggest you to take a screenshot of your configuration then you may just copy it.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
