wecmas
Nov 15, 2016Follower
FVS336Gv2 4.3.3-6 Firmware problem
Hello,
I've updated my firewall to firmware version 4.3.3-6, but then rebooted and can no longer log in with the IP address I had before reboot.
I have tried to see what IP address it has now but I can not see anything, I do not know how to access it again.
The model is: FVS336Gv2
Thank you very much for your help.
- JohnRoNETGEAR Employee Retired
Hello wecmas,
Welcome to the community!
Do an IP config, see if you are still getting an IP address from the router/firewall. If you are, the default gateway is the IP address of the router/firewall. Can you also tell me the status of the lights?
Thanks,
Hi wecmas,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
