Noctaire
Feb 02, 2018Aspirant
FVS336Gv2 Bandwidth limitations...?
So...this one was unexpected. Got an FVS336Gv2, been running just fine on a 1.5M connection. Moved it over to business class, cable at 100M down, 10M up. Speedtest run behind the firewall show ...
- Feb 05, 2018
Hi Noctaire,
As per the FVS336Gv2 data sheet here, it has a LAN-to-WAN throughput of 60Mbps. To take advantage of the upgraded connection which is about 100Mbps you have subscribed, you will need a firewall router that has a LAN-to-WAN throughput that is greater than 100Mbps.
DaneA
NETGEAR Community Team
DaneA
Feb 05, 2018NETGEAR Employee Retired
Hi Noctaire,
DaneA
- NoctaireFeb 05, 2018Aspirant
Thanks. That still leaves 30M unaccounted for but definitely helps me narrow the troubleshooting.
