mvaar
Sep 11, 2015Aspirant
FVS336Gv2 full tunnel no internet
I have upgraded the firmware to latest (4.3.3-5) and I am using the latest vpnclient lite version 6.x. Running windows 10 pro 64 bit. I set up the gateway as enumerated in the manual and I can co...
DaneA
Sep 14, 2015NETGEAR Employee Retired
Hi mvaar,
I think if you want full tunnel support, you should use SSL VPN instead and check "full tunnel support" in the SSL VPN Client setup page of the FVS336Gv2.
Check pages 8-15 on the link below. Is this how you configured a client-to-box VPN?
http://www.downloads.netgear.com/files/GDC/FVS318N/QSGVPN_4Apr2012.pdf
I look forward to your response. Feel free to post screenshots of your setup. Welcome to the community! :smileyhappy:
DaneA
Netgear Community Team
mvaar
Sep 14, 2015Aspirant
I followed the instructions in this manual - http://www.downloads.netgear.com/files/GDC/VPNG01L/VPNClient_UM_27May2015.pdf
Remember, I have a fvs336gv2 with firmware 4.3.3-5, not a fvs318.
Yes, it is a client to gateway VPN.
I followed the gateway setup exactly as described in appendix A, manually configuring a gateway, with the addition of (edge) xauth.
I assigned client IP address of 192.168.7.10, while connecting (tunneling) to the remote subnet 192.168.120.0/255.255.255.0 . The endpoint is 192.168.120.1. It is one of the VLANs I set up on the router.
On the router, all outbound traffic is allowed so I saw no reason to add any firewall rule ( as some have indicated elsewhere that to make full tunnel possible you need to add firewall rules or even routes). I am a little hazy on these concepts though, I admit.
So with split tunneling, everything works. I can see the remote subnet and I can ping to the internet- all traffic except to the 192.168.120.0 is going from my local gateway - 192.168.70.1 .
With full tunnel, I can see everything in the 192.168.120.0 as expected but I cannot even ping IP addresses on the internet.
