I_am_jbcbussoft's avatar
Jun 28, 2016
Loss of internet after tunnel connection
I have just setup a tunnel between a FVS318N and the Prodafe client. I then use Remote Desktop to control the pc. When I do this I lose internet capability. How can I avoid this?
  • This occurred while testing this in my office. When I set it up on-site this did not happen. I posted the question before deploying the equipment hoping to get a resolution but there was no need as this is not a problem on the live setup.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi I_am_jbcbussoft,
    Welcome to the community! :)
    The VPN tunnel is up between the FVS318N and a PC where the ProSAFE VPN Client software is installed.  Then, on the same PC where the ProSAFE VPN Client software is installed, you used Remote Desktop to control a PC that is on the local network of the FVS318N via the VPN tunnel.  Once you got connected using RDP, you suddenly lose internet connection on the PC where the ProSAFE VPN Client software is installed.  Am I right?  If ever I'm right, here are my questions below:
    a. Was this working fine before?
    b. If you will not be using Remote Desktop, are you able to access the internet just fine and at the same time connected to the VPN tunnel?
    c. Have you tried using other PCs/laptops where the ProSAFE VPN Client software is installed to connect via VPN then use Remote Desktop?
    d. What is the current firmware version of the FVS318N?
    I look forward to your response.
    DaneA
    NETGEAR Community Team
    • Danthem's avatar
      Danthem
      Hey,
      I've seen this recently, not sure if it's an issue with Windows or a new minor version of the VPN client.
      What you need to do is disable split tunneling -> save -> enable split tunneling  -> save. After that it should work again. Split tunneling can be disabled/enabled under the "IKE V1 Parameters".
      Please let me know what version of the client you are running as well
ProSupport for Business
