bzness
Jan 14, 2018Aspirant
FVS336gv2 not connectiong with xfinity
Ok, so I have an Xfinity account and a small home network behind an FVS316G firewall. Everything seems to be OK at the moment. However, Xfinity just upgraded me to a much faster connection (over 100 ...
bzness
Jan 16, 2018Aspirant
Hi DanA,
thanks for your help. Yes, I had to turn off the modem and turn it on again, then it seemed to connect. Thanks, Xfinity had told me it would work "just by connecting the router".
Anyway, the first attempt only netted me a download and upload speed of 1.5 Mbps. Looking at the router it had defaulted to a a slow WAN speed for both up and down.
I set that manually to 1 Gbps (down), and 100 Mbps (up), and the speed went up to 27 Mbps down and 16 up. The hardware has the latest firmware, and there is notthing really done other than moving data to the LAN and back.
So, when you say 60 Mbps, is that a number that you can get with just one WAN connection active, or is that a speed you can get with both WAN connections combined (which is not an option for me). If with one WAN connection, what are the settings I should check to get the speed to 60?
Since my internet speed is quite a bit higher, which Netgear firewall would allow me to get a true, say, 250 Mbps speed for downloads (uploads are still restriced by the ISP spped), FOR A SINGLE WAN connection.
DaneA
Jan 16, 2018NETGEAR Employee Retired
The LAN-to-WAN (or WAN-to-LAN) throughput is the actual amount of data that can be transmitted from LAN to WAN or vice versa. Either you are using single WAN port or both WAN ports of the FVS336Gv3 (either set to Load Balancing mode or Auto-Rollover mode), still the LAN-to-WAN throughput is 60Mbps.
The FVS336Gv3 has a LAN-to-WAN throughput of 350 Mbps but this has been discontinued along with the whole NETGEAR ProSAFE VPN Firewall product line which has been declared EOL (End-of-Life) last September 1, 2017. Check the announcement here.
DaneA
NETGEAR Community Team
- DaneAJan 21, 2018NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
- bznessJan 21, 2018Aspirant
Hi DaneA.
thanks for your help. I decided to use the FVS336gv2 temporarily until I can sort everything out. But I'd like to know how I can get the 60 Mbps you had mentioned. How do I have to set up the firewall to get that?
I downloaded the latest firmware and installed it.
I then did a factory reset.
When I connect with my computer to the xfinity modem directly, I get 300 Mbps download (and about 15 upload).
When I use the just prepared FVS336Gv2 and only my computer directly attached to it, the download is 30 Mbps, the upload about 15.
Obviously there must be some settings that reduce the WAN speed by a factor of 2.
Which settings are those? How do I get to the 60 Mbps you had mentioned?
Thanks.
- DaneAJan 22, 2018NETGEAR Employee Retired
Kindly try the following steps below:
1. Disable (or delete) the firewall rules configured in the FVS336Gv2 then observe if it helps.
2. On the web-GUI of the FVS336Gv2, go to Security > Firewall > Attack Checks. Then, uncheck the boxes that says 'Block TCP Flood' and 'Block UDP Flood' and click Apply. Observe if this helps. Refer to the image below:
If ever the same problem occurs, I suggest you to open a chat or online case with NETGEAR Support at anytime for further assistance.
DaneA
