BluepenD's avatar
BluepenD
FVS336Gv2 vs FVS336Gv3
What is the difference between the FVS336Gv2 vs FVS336Gv3 network routers?  I have the older FVS336Gv2 and just wanted to better understand the differences.
  • JennC's avatar
    Nov 07, 2015
    Hello BluepenD,
    Welcome to the community!
    The main difference between the 2 versions is the performance.
    1. FVS336Gv2
    •      LAN-to-WAN throughput: 60mbps
    •      IPsec VPN (3DES): 16 Mbps
    •      SSL VPN: 10 Mbps
    2. FVS336Gv3
    • LAN-to-WAN throughput:  350mbps
    • IPsec VPN (3DES): 78Mbps
    • SSL VPN: 14Mbps
    You may check data sheets of FVS336Gv2 and FVS336Gv3 for more detailed features of each.
ProSupport for Business
