BluepenD
Nov 06, 2015Aspirant
FVS336Gv2 vs FVS336Gv3
What is the difference between the FVS336Gv2 vs FVS336Gv3 network routers? I have the older FVS336Gv2 and just wanted to better understand the differences.
- Nov 07, 2015
Hello BluepenD,
Welcome to the community!
The main difference between the 2 versions is the performance.
1. FVS336Gv2
- LAN-to-WAN throughput: 60mbps
- IPsec VPN (3DES): 16 Mbps
- SSL VPN: 10 Mbps
2. FVS336Gv3
- LAN-to-WAN throughput: 350mbps
- IPsec VPN (3DES): 78Mbps
- SSL VPN: 14Mbps
You may check data sheets of FVS336Gv2 and FVS336Gv3 for more detailed features of each.
JennC
Nov 07, 2015NETGEAR Employee Retired
Hello BluepenD,
1. FVS336Gv2
- SSL VPN: 10 Mbps
2. FVS336Gv3
- SSL VPN: 14Mbps
BluepenD
Dec 01, 2015Aspirant
Thanks this was a great help.
