picgla
Aug 15, 2017Follower
fvs336gv3 inbound rules not working
I have an fvs336gv3, firmware 4.3.5-3. I have defined 9 inbound lan-wan rules similar to the following: Service Name Filter LAN Server IP Address LAN Users WAN Users QOS ...
- Sep 05, 2017
i had two problems contributing to this failure.
1) i followed the suggestion to delete all current affected rules and services, then rebooted. after reinstalling the services and recreating the rules, i rebooted again.
inbound rules still did not function. problem was:
2) verify correct external IP with dyndns.
after updating the external dynamic dns address with dyndns.org, all rules functioned as expected.
thank you very much for the suggestions and good leads.
JohnC_V
Aug 17, 2017NETGEAR Employee Retired
Hi picgla,
Welcome to the community!
It seems that this is working before and I see no other issues in here unless there is a new port opened and now having a conflict. These ports should be accessible first in the local network and if it is not working on the local side then it will not work on the public network. Have you ever checked if there is any ports that is having a conflict to your previous setup? Please try resetting the firewall to factory default and re-create those policies. Please also check if these ports are open on the public network using a port scanner.
