picgla
Aug 15, 2017Follower
fvs336gv3 inbound rules not working
I have an fvs336gv3, firmware 4.3.5-3. I have defined 9 inbound lan-wan rules similar to the following: Service Name Filter LAN Server IP Address LAN Users WAN Users QOS ...
- Sep 05, 2017
i had two problems contributing to this failure.
1) i followed the suggestion to delete all current affected rules and services, then rebooted. after reinstalling the services and recreating the rules, i rebooted again.
inbound rules still did not function. problem was:
2) verify correct external IP with dyndns.
after updating the external dynamic dns address with dyndns.org, all rules functioned as expected.
thank you very much for the suggestions and good leads.
picgla2
Sep 05, 2017Aspirant
- JohnC_VSep 06, 2017NETGEAR Employee Retired
Thank you for that information. Atleast, you were now able to work with your inbound rules. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
