sinman
Apr 07, 2017Aspirant
fvs336gv3 protocol binding
Hi I have a dual wan set up WAN1 - Leased line for VoIP WAN2 - ADSL for all other traffic (has high latency) We have configured Weighted LB, Protocol binding of all SIP traffic to go to WAN...
- Apr 13, 2017
Hi sinman,
Welcome to the community! :)
Let us try this: kindly remove the protocol binding for the VoIP that is configured then just define an outbound policy for it in the firewall rules and observe.
What is the current firmware version of the FVS336Gv3?
DaneA
NETGEAR Community Team
DaneA
Apr 13, 2017NETGEAR Employee Retired
Hi sinman,
DaneA
- sinmanApr 13, 2017Aspirant
Hi DaneA
Thanks for the welcome :-)
Am I correct in thinking that the WAN users IP is the destination (SIP server) and the NAT IP should be the WAN connection I want it routed via (WAN1)?
I will give this a shot and report back
Firmware is: 4.3.3-6
Thank you for your help, I really appreciate it
Thanks
Simon
- DaneAApr 26, 2017NETGEAR Employee Retired
I just want to follow-up. Were you able to try my suggestion? If yes, what is the result?
Also, I suggest that you to upgrade the firmware of the FVS336Gv3 to v4.3.5-3 then perform a factory reset on it. Afterwards, reconfigure it from scratch in order to start clean using the latest firmware version. You may download firmware v4.3.5-3 here.
DaneA
