BenHelder
Mar 01, 2016Follower
FVS336GV3 suddenly starts to sends Log files
I am not sure why, but all out of the blue it is starting to send out Logfiles by email to my account. Why? this is a copy of it.. a bit.... and i dont understand why it would do such a thing ....
sonny_E
Aug 27, 2016Guide
Noticed since setting it up never any firewall messeges ever? There are system messages but anything from the [firewall] is absent. Any help on this...
Did some port scans and nothing showed up in the log. Everything was stealth port wise.
- DaneAAug 28, 2016NETGEAR Employee Retired
Hi sonny_E,
Welcome to the community! :)
Kindly answer the questions below:
a. What is the model of the NETGEAR VPN Firewall you are referring to?
b. On the web-GUI of your NETGEAR VPN Firewall, go to Monitoring > Firewall Logs & E-mail. Are all options check in the Routing Logs, System Logs and Other Event Logs? It would be best if you post a screenshot of it.
c. What is the current firmware version of the NETGEAR VPN Firewall you are referring to?
d. Have you tried to perform a factory reset then reconfigure your NETGEAR VPN Firewall then check if same problem occurs?
I look forward to your response.
DaneA
NETGEAR Community Team
- sonny_EAug 28, 2016Guide
Hello
FVS336v3 with the latest firmware as of a couple days back. See what you think? Thanks so much Only lets you paste so much...
Sun Aug 28 09:08:18 2016((GMT-0800)) [FVS336GV3][System][LOGIN] SSL_INFO : Login Successful for geardomain user admin(Admin) from host 192.168.1.100
Fri Aug 26 20:58:22 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change.
Fri Aug 26 20:58:22 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Fri Aug 26 20:58:22 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] p->perfect 0000000000000000 p->h a8000000044c4e00
Fri Aug 26 20:58:22 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_dump(tp a80000000610ea00,fh 0x0,skb a800000003596380,t a800000006d92010),p a80000000610e980,r 0000000000000000,b a800000006d92038
Fri Aug 26 20:58:22 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_change(tp a80000000610ea00,handle 0x00000000,tca a800000007c05a80,arg a800000003563950),opt a800000004a70c30,p a80000000610e980,r 0000000000000000,*arg 0x0
Fri Aug 26 20:58:22 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_get(tp a80000000610ea00,handle 0x00000000)
Fri Aug 26 20:58:22 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_init(tp a80000000610ea00)
Fri Aug 26 20:58:22 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_delete(tp a80000000610ea00,arg 0xa80000000610e908),p a80000000610e980,f 0000000000000000
Fri Aug 26 20:58:22 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_walk(tp a80000000610ea00,walker a800000003653900),p a80000000610e980
Fri Aug 26 20:58:22 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_destroy(tp a80000000610ea00),p a80000000610e980
Fri Aug 26 20:57:57 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.4093: no IPv6 routers present
Fri Aug 26 20:57:55 2016((GMT-0800)) [FVS336GV3][System][NIMF] Link Status of WAN1 is LINK UP
Fri Aug 26 20:57:47 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.4093: add 33:33:ff:0d:13:db mcast address to master interface
Fri Aug 26 20:57:47 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.4093: add 33:33:00:00:00:01 mcast address to master interface
Fri Aug 26 20:57:47 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.4093: add 01:00:5e:00:00:01 mcast address to master interface
Fri Aug 26 20:57:47 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.4093: Setting MAC address to 10 da 43 0d 13 db.
Fri Aug 26 20:57:47 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] IPsec: device down: eth0.4093
Fri Aug 26 20:57:47 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.4093: del 33:33:00:00:00:01 mcast address from master interface
Fri Aug 26 20:57:47 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.4093: del 33:33:00:00:00:01 mcast address from vlan interface
Fri Aug 26 20:57:47 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.4093: del 01:00:5e:00:00:01 mcast address from master interface
Fri Aug 26 20:57:47 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.4093: del 01:00:5e:00:00:01 mcast address from vlan interface
Fri Aug 26 20:57:47 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.4093: del 33:33:ff:10:75:00 mcast address from master interface
Fri Aug 26 20:57:47 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.4093: del 33:33:ff:10:75:00 mcast address from vlan interface
Fri Aug 26 20:57:46 2016((GMT-0800)) [FVS336GV3][System][NIMF] nimfAdvOptSetWrap: NIMF table is NimfStatus
Fri Aug 26 20:57:46 2016((GMT-0800)) [FVS336GV3][System][NIMF] Restarting WAN1 for IPv4
Fri Aug 26 20:57:46 2016((GMT-0800)) [FVS336GV3][System][NIMF] Link Status of WAN1 is LINK UP
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change.
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] p->perfect 0000000000000000 p->h a800000004a70e00
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_dump(tp a80000000354af80,fh 0x0,skb a800000006d99800,t a800000006d9e010),p a80000000354af00,r 0000000000000000,b a800000006d9e038
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_change(tp a80000000354af80,handle 0x00000000,tca a800000007c05a80,arg a800000003563950),opt a80000000706be30,p a80000000354af00,r 0000000000000000,*arg 0x0
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_get(tp a80000000354af80,handle 0x00000000)
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_init(tp a80000000354af80)
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] p->perfect 0000000000000000 p->h a800000004a70c00
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_dump(tp a80000000610ea00,fh 0x0,skb a800000006da4e00,t a800000006da5010),p a80000000610e980,r 0000000000000000,b a800000006da5038
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_change(tp a80000000610ea00,handle 0x00000000,tca a800000007c05a80,arg a800000003563950),opt a800000004a70e30,p a80000000610e980,r 0000000000000000,*arg 0x0
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_get(tp a80000000610ea00,handle 0x00000000)
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] tcindex_init(tp a80000000610ea00)
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.1: no IPv6 routers present
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.1: add 33:33:ff:0d:13:cc mcast address to master interface
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.1: add 01:00:5e:00:00:01 mcast address to master interface
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.1: add 33:33:00:00:00:01 mcast address to master interface
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] VLAN (eth0.1): Setting underlying device (eth0) to promiscious mode.
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] device eth0 entered promiscuous mode
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] eth0.1: Setting MAC address to 10 da 43 0d 13 cc.
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] Loading ifDev module
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] using bcm switch bcm53115
Fri Aug 26 20:57:42 2016((GMT-0800)) [FVS336GV3][Kernel][KERNEL] Loading /home/release/FVS336GV3_P2.0/01JuneM15_v4_3_4_1/fvs336gv3/fvs336gv3_common/comps/switchdriver/src/switchdriver/linux/kernel/mii/octeon/mii.c - sonny_EAug 28, 2016Guide
Thanks for the help. Did not have unicast checked off and that did it. Thx
- DaneAAug 29, 2016NETGEAR Employee Retired
Hi sonny_E,
I'm glad that you have figured it out. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
