stevenshaw
Jul 22, 2019Tutor
FVS336v3 NBN connection
Does anyone know if the FVS336v3 can be connected to the Austrailan NBN connecting via the service provider TPG. No matter what I have done to date it will not connect and I have tried most?
Also does the new model BR500 connect to the NBN?
- JohnC_VNETGEAR Employee Retired
Hi stevenshaw,
Welcome to our community! :)
We don't really have any compatibility issues regarding NBN. May I know if the FVS336v3 is going to be connected to a router or modem? You may need to check the IP address of the router as it will cause an IP conflict connecting from NBN.
JohnCarloV
NETGEAR Community Team
The main issue is in this link https://community.tpg.com.au/t5/Broadband-Internet/Alternate-router-to-use-on-HFC/td-p/863 on the first page down in the thread the VLAN settings linked to the 802.1Q tag.
TPG set up is in the following link.
http://tpg.com.au/support/setup-nbn-hfc/modem-wiring-support.html
https://community.netgear.com/t5/Hardware-VPN-Firewalls-and/FVS336-V2-NBN/m-p/1701247 this link asked the same question but for the FVS336v2 - no answer either.
Also I am not interested in the VOIP function.
