moti
May 27, 2016Aspirant
FVS336V3 Router - web interface page for LAN groups takes over a minute to open
Hi, The router is on the latest firmware 4.3.3.-6. Everything works great except this annoying problem. To see the full DHCP leases I should open the page "Network Configuration" -> "LAN Settings...
JohnRo
May 27, 2016NETGEAR Employee Retired
Hello moti,
Welcome to the community!
I don't believe this is an issue, I have used multiple routers using this firmware (and older firmware as well) and all of them take a minimum of a minute (depends on the number of devices connected) to load the LAN Groups page. I have tested this on multiple browsers as well and all shows the same result.
Let me know if you have more questions.
Thanks,
moti
May 28, 2016Aspirant
Thanks John, I appreciate the effort you put into checking this. It may not be an "issue" in the sense of "this is a bug" but waiting over a minute for this page to load is IMHO a serious usability issue. My older Linksys LRT224 router for example (which is a slower router when it comes to download speed over the same cable connection) is loading the DHCP status page almost instantly.
I hope the Netgear Product Management folks are monitoring this forum and will consider improving it....
Cheers,
Moti
- JohnRoMay 30, 2016NETGEAR Employee Retired
Hi moti,
I totally agree with what you said, I'm pretty sure this can be improved on future firmware releases. For the meantime, I suggest writing a post on our Idea Exchange Board. This is monitored by the engineering team and if more people request for it (by giving a kudos - up arrow), it will be prioritized.
Thanks,
- motiJun 04, 2016Aspirant
Good idea - will do.
Thanks!
Moti
