gregd96067
Aug 04, 2023Aspirant
R6250 browser interface
In my home I have an Arris S33 modem, a Trendnet teg-s24g gigabit switch, and a Netgear R6250 Router.
https://www.surfboard.com/products/cable-modems/s33/
https://www.trendnet.com/products/product-detail?prod=545_teg-s24g
In recent days, following a series of local power outages, we could no longer connect either our Firestick or our phones to Wi-Fi.   Some fiddling on the part of Vyve tech support (our cable TV and Internet provider) resulted in resetting everything and we can finally connect our devices.
During (and subsequent to) the Wi-Fi outage, I tried to connect  to https://www.routerlogin.net/ and https://www.routerlogin.com/.  The instructions informed me that once I browsed to one of those URLs that a login prompt would appear.  That did not happen.
I have referenced this article:
https://kb.netgear.com/23664/How-do-I-locate-my-router-s-IP-address
I can browse to https://192.168.0.1/Login.html and log in to my Arris modem.   Browsing to 192.168.1.1 I get an error "This site can’t be reached."
Is there an interface associated with the Netgear R6250 Router?  How might I reach it?
- I never resolved the issue. My cable provider sent out a tech, that didn't help. Reset the router more than once, power-cycled all the gear, triggered multiple hardware resets. Nothing helped. I ended up purchasing a new router rather than continuing to fight this issue.
 Thanks for the assist folks.
- microchip8MasterDon't use HTTPS, use plain HTTP to login into either routerlogin.net or 192.168.1.1- gregd96067AspirantThe URL routerlogin.net automatically redirects to HTTPS. I cannot influence that.
 Entering 192.168.1.1 into Chrome or Firefox, there is no HTTPS being referenced. Firefox returns this:The connection has timed out The server at 192.168.1.1 is taking too long to respond. The site could be temporarily unavailable or too busy. Try again in a few moments.
 If you are unable to load any pages, check your computer’s network connection.
 If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the web.- FURRYe38Guru - Experienced UserWith the router disconnected from the ISP modem, press the reset button in back for 10 seconds then release. After the router comes to partial ready, can you access 192.168.1.1 with a wired PC and web browser here?
