mpgroup
Sep 10, 2015Aspirant
FVS338 doesn't filtering https traffic
My FVS338 doesn't filtering https traffic, despite I'd upgrade the firmware to 3.1.1-08. Pls help.
mpgroup
Sep 14, 2015Aspirant
Hi DaneA,
attached are 3 Screenshots. I hope the pics include the required data. First I insert the pics in a private album, hope you can access, cause I answer you.
DaneA
Sep 14, 2015NETGEAR Employee Retired
Hi mpgroup,
It seems that you tried to block https://facebook.com or any other HTTPS sites. I am sorry to inform you that it is not possible to block HTTPS sites on the FVS338 because it does not support Application Security or Blacklist like the Prosecure devices of Netgear which is about to be EOL.
DaneA
Netgear Community Team
