1stoptech
Mar 31, 2020Aspirant
FVS338 Port Forward to custom port
I am trying to add 2 computers to remote desktop from home. The computers have 33** custom listening port numbers. I can remote into the computers using ip address:33** from within the network but not from home going through the FVS338. I have also added a firewall rule on each workstation allowing access to the specific port on each computer.
I have gone to Security-Services and added a custom service with the port number for each of the 2 computers we want to add.
Then to Security-Firewall and selected the service custom port and added the static ip of a computer in SEnd to Lan Server, Wan users any and log never.
Thanks, while your solution was not the exact fix, it got me to looking at all other rules, the first firewall rule service was set to "any", after making it's own service assignment all else started to work.
- JohnC_VNETGEAR Employee Retired
Hi 1stoptech,
Welcome to our community! :)
It seems that you are trying to setup Inbound Rules in order for you to gain access to your computer via RDP. It is working locally right? May you be able to try enabling the Secure HTTP Management? Administration > Remote Management - Allow Secure HTTP Management - Enable then test if the port is online by checking it on a port scanner. If it did work, then please try to disable all the Inbound rules except for the one that you need to open.
You may also try to delete all the inbound rules and recreate it. Please share some screenshots too.
John
NETGEAR Community Team
- 1stoptechAspirant
- Nov 30, 2019Retired_Member
