mjcataldo
Jan 11, 2017Aspirant
FVS338 Requires a Reboot Every Few Hours
I've factory reset my FVS338 and the device was working. Just a few hours later all connected devices go offline (invalid IP configuration). Where do I start to diagnose this type of issue? Do the...
mjcataldo
Jan 12, 2017Aspirant
It looks the logs don't persist across reboots, does anyone know if that's correct?
JohnRo
Jan 16, 2017NETGEAR Employee Retired
Hi mjcataldo,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
