bcassell's avatar
bcassell
CM1000 requiring rebooting several times a day (Comcast)
I recently purchased a Netgear CM1000 for use on Comcast and several times a day the internet just stops working despite all lights still showing green.  When this happens I can't even log into the web management app.  Turning the modem off and back on removes the problem, but this is really annoying to have to do multiple times a day!  Any advice is welcomed.  Here are some pertinent pieces of information:
Hardware Version2.02
Firmware VersionV2.01.14
Acquire Downstream Channel639000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnableBPI+
IP Provisioning ModeHonor MDDIPv6 only
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM25617639000000 Hz-1.7 dBmV39.1 dB10
2LockedQAM2561543000000 Hz-1.3 dBmV40.1 dB00
3LockedQAM2562549000000 Hz-1.2 dBmV40.1 dB20
4LockedQAM2563555000000 Hz-1.3 dBmV40.0 dB10
5LockedQAM2564561000000 Hz-1.4 dBmV39.9 dB20
6LockedQAM2565567000000 Hz-1.3 dBmV40.0 dB00
7LockedQAM2566573000000 Hz-1.5 dBmV39.9 dB30
8LockedQAM2567579000000 Hz-1.4 dBmV39.7 dB20
9LockedQAM2568585000000 Hz-1.5 dBmV39.7 dB20
10LockedQAM2569591000000 Hz-1.5 dBmV39.7 dB40
11LockedQAM25610597000000 Hz-1.7 dBmV39.6 dB70
12LockedQAM25611603000000 Hz-2.0 dBmV39.3 dB30
13LockedQAM25612609000000 Hz-2.5 dBmV39.3 dB50
14LockedQAM25613615000000 Hz-2.0 dBmV39.3 dB60
15LockedQAM25614621000000 Hz-1.7 dBmV39.3 dB40
16LockedQAM25615627000000 Hz-1.7 dBmV39.2 dB20
17LockedQAM25616633000000 Hz-1.7 dBmV39.3 dB10
18LockedQAM25618645000000 Hz-1.8 dBmV39.3 dB20
19LockedQAM25619651000000 Hz-1.7 dBmV39.1 dB30
20LockedQAM25620657000000 Hz-1.7 dBmV39.2 dB30
21LockedQAM25621663000000 Hz-1.6 dBmV39.1 dB30
22LockedQAM25622669000000 Hz-1.6 dBmV39.1 dB10
23LockedQAM25623675000000 Hz-1.5 dBmV39.1 dB00
24LockedQAM25624681000000 Hz-1.5 dBmV39.0 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA15120 Ksym/sec30100000 Hz45.5 dBmV
2LockedATDMA25120 Ksym/sec36500000 Hz45.5 dBmV
3LockedATDMA35120 Ksym/sec17300000 Hz43.5 dBmV
4LockedATDMA45120 Ksym/sec23700000 Hz45.5 dBmV
TimePriorityDescription
2017-01-22, 21:03:53Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-22, 21:03:58Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-22, 21:04:05Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-22, 21:04:49Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-22, 21:04:49Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-22, 21:05:09Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-22, 21:05:10Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-22, 21:05:28Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-22, 21:05:29Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-22, 21:05:48Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedCritical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedCritical (3)No Ranging Response received - T3 time-out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 19:26:40Critical (3)No Ranging Response received - T3 time-out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 21:01:18Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 21:01:21Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 21:01:27Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 21:02:09Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 21:02:09Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 21:02:29Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 21:02:30Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 21:02:49Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 21:02:50Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 21:03:09Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 22:53:14Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 23:00:30Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 23:00:35Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 23:00:41Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 23:01:11Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 23:01:12Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 23:01:32Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 23:01:32Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 23:01:53Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 23:01:54Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
2017-01-24, 23:02:12Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=a0:04:60:fc:8d:a0;CMTS-MAC=00:1d:45:70:69:60;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedNotice (6)Honoring MDD; IP provisioning mode = IPv6
This event log comes shortly after I had to restart my modem for the second time in the last 2 hours!
  • Interesting, the overall problem was solved for me and several neighbors.  Cox replaced a mini-amplifier in the box at the street. However, I found the item that had the largest impact to overall network stability was unplugging our Ac1200's extenders. interestingly, we each had one on our individual networks and removing them resolved the overall issues.
