byteisg
Aug 03, 2012Aspirant
FVS338 WAN Throughput restricted
Hi All, I've recently had upgraded my adsl line to fibre with download speed of average 70Mbps but if I use my FVS338 router the download speed appears restricted to around 35Mbps, however if I use...
byteisg
Sep 24, 2012Aspirant
jmizoguchi wrote: All prosafe router from the netgears.com product page under spec will have "WAN-LAN throughput" spec so choose what you want.
I don't quite trust that as my current prosafe should be able to handle 75 Mbps according to this link:
http://www.netgear.co.uk/business/products/security/wired-VPN-firewalls/FVS338.aspx#two
"Throughput: LAN-to-WAN: up to 75 Mbps 3DES IPsec tunnel: Up to 19 Mbps"
So it's kind of misleading or a bug.
Thanks.
