byteisg
Aug 03, 2012Aspirant
FVS338 WAN Throughput restricted
Hi All, I've recently had upgraded my adsl line to fibre with download speed of average 70Mbps but if I use my FVS338 router the download speed appears restricted to around 35Mbps, however if I use...
jmizoguchi
Sep 25, 2012Virtuoso
Couldn't be any simpler. Don't understand your posting meant
Should define better. Don't halen someone because you did not explain it
VPN tunnel all has restriction in traffice. All other router has same spec
