Andreapier
Dec 04, 2018Aspirant
FVX538 Firewall Bandwidth Management
Is it possible to limit bandwidth on one (or more) specific LAN ports?
I.E., I'd like to set LAN1 to 20Mbps (in/out) and LAN2 to 80Mbps.
Thank you!
Andrea
Hi Andreapier,
Welcome to our community! :)
As per checking, FVX538 does not support rate limiting per LAN and this type of configuration is only supported by a fully managed L3 Switch.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- JohnC_VNETGEAR Employee Retired
Hi Andreapier,
- AndreapierAspirant
Hi JohnCarloV!
Thanks for your answer, I'll search for a small managed switch to do the job. :-)
Best regards,
Andrea
