nospeak's avatar
nospeak
RS700 firewall
hi…
i do not want to use netgear armor on the router and was wondering if i deactivated it will i still have firewall protection other then the netgear armor….i do not like bitdefender
  • Default should be good. Nothing to configure unless you need something specific.
  • plemans's avatar
    You do.
    I rarely use armor. I might test it for the first 30 days after getting a new router and then just disable it.
    • nospeak's avatar
      nospeak
      can you recommend any settings i may need to adjust or are default settings are good?
      • FURRYe38's avatar
