BeagleIL
Sep 20, 2013Aspirant
Help configuring FVS336Gv2
I recently purchased a FVS336Gv2 and need a bit of help making sure I configure it properly. I currently have 5 static IPs from my ISP that I use on various WWW servers. These 5 servers, all running L...
jmizoguchi
Sep 24, 2013Virtuoso
I forgot about top off my ahead earlier
NAT IP: Specifies whether the source address of the outgoing packets on WAN should be assigned WAN interface address OR different one.
NAT single IP is on: The Interface to which the NAT IP belongs to. All the outgoing packets on WAN will be routed through the specified WAN interface only.
v WAN Interface Address: All the outgoing packets on WAN will be assigned WAN interface address.
v Single Address: All the outgoing packets on WAN will be assigned the specified IP address.
Note: This option will be available only when WAN mode is "NAT". The IP address specified should fall under the WAN subnet.
