kcirillo's avatar
Sep 22, 2015
How do I allow multiple users to VPN in at once?
I am working with an FVS318G and have always had one user connect with the preshared key even though I do have a user account set up for him. We now have one more user that needs to connect however i...
  • JohnRo's avatar
    Sep 22, 2015
    Hello kcirillo,
    Welcome to the community!
    When using X-auth you will still need to use the passphrase and requires additional login information for the tunnel to identify which user is accesing it.
    You have to make sure that the login information are defined on the User Database, see page 139 of the documentation.
    Hope it helps! If you have more questions feel free to ask.
    Thanks,
ProSupport for Business
