stevefigueras
Dec 19, 2014Aspirant
How forward port on FVS318G ?
Hello i need to forward port 443 on my FVS318G for watching an Ip Camera from web. This FVS318G is behind a internet box and the ip cam have a 192.168.1.8 fixed adress. Can you help me ?
stevefigueras
Jan 02, 2015Aspirant
Hello first thanks you to help me :)
I show you here what i've done on Ip CAM, on ISP box and on FVS318G.
But when i enter Public IP:3504 or Dydns:3504 embed with camera, nothing work :(
I precise i try from nomad access not linked by wifi or ethernet to my isp box to avoid looback if my FVS318G don't support it.
I search about explication :
On LAN when i enter 192.168.1.9:88 : it work no problem but if i choose the 3504 port there is an error and nothing happen...
Do you know if my operation on screen capture is corect ?
