spaceobh
Sep 27, 2015Aspirant
How to configure FVS318N to transmit NAT'ed LAN IP in FTP tranfers in stead of Firewalls WAN-IP.
I'm having this problem. Remote site is connected to the internet in a fixet, multiple IP-adress MPLS setup. The LAN side is presently protected by a Zyxel Zywall, but for a variety of reasons I...
- Oct 14, 2015
Hi Samir
Apologies for my delayed response.
I'll try to test the setup you are suggesting the next time I'm at the location, but since it's in east Greenland there are no planned trips - I only go there when absolutely necessary.
I will need to close my post here for now, and I'd like to thank all of you for your help.
When I initially opened the case I thought I had just missed to set a checkmark somewhere, and that I could sort of just "copy-paste" the rules etc. from the Zyxel to the netgear.
Cheers
DaneA
Sep 30, 2015NETGEAR Employee Retired
Hi spaceobh,
It seems that you have already contacted NETGEAR Support about your concern. What I think is that you need to have an outbound rule for that FTP server to send traffic out on that secondary wan address of 111.111.111.102 instead of the device NAT IP of .101.
Welcome to the community! :smileyhappy:
DaneA
NETGEAR Community Team
- spaceobhOct 01, 2015Aspirant
Hi DaneA
Thanks for your reply :smileyhappy:
Yes, I did submit my problem to Netgear support, however, I have been receiving more questions than answers :smileyfrustrated:
Ahhh, It may be the case, that I need to create a specific outbound rule in addition to the Any-Any rule that already exists.
Like:
Index Service Filter LAN users WAN Users Qos Bandwth
1 or 2? Any ALLOW 192.168.1.102 "FTP-server IP" - -
Is there a hierachy in the position of those rules?
If so, must the specific outbound rule be no 1 or no 2?
Just to be nit-picky: Its a FTP-client pushing files from 192.168.1.102/111.111.111.102 to the receiving FTP-server on "FTP-server IP"
Thanks again :smileyhappy:
- DaneAOct 01, 2015NETGEAR Employee Retired
Hi spaceobh,
Like:
Yes, hierarchy should be observed on which rule should be first be checked. You may specify the rule as no. 1.
DaneA
- spaceobhOct 06, 2015Aspirant
Well, this is not easy to solve, primarily because the FVS318 is at a very remote place on a very, very slow connection and testing impairs production.
Since teh current Zyxel is still functioning I will put the efforts to configure the FVS318 on hold until action is needed.
Thanks a lot for your contribution.
