spaceobh
Sep 27, 2015Aspirant
How to configure FVS318N to transmit NAT'ed LAN IP in FTP tranfers in stead of Firewalls WAN-IP.
I'm having this problem. Remote site is connected to the internet in a fixet, multiple IP-adress MPLS setup. The LAN side is presently protected by a Zyxel Zywall, but for a variety of reasons I...
- Oct 14, 2015
Hi Samir
Apologies for my delayed response.
I'll try to test the setup you are suggesting the next time I'm at the location, but since it's in east Greenland there are no planned trips - I only go there when absolutely necessary.
I will need to close my post here for now, and I'd like to thank all of you for your help.
When I initially opened the case I thought I had just missed to set a checkmark somewhere, and that I could sort of just "copy-paste" the rules etc. from the Zyxel to the netgear.
Cheers
SamirD
Oct 09, 2015Prodigy
Thank you for the diagrams as it makes it very clear. I wish others could do that in their threads!
So normally (and probably your current setup), the zyxel is in place of the netgear in the diagram showing the computer on the lan, correct? If so, you can plug a [i]default configuration[/i] 318n wan port into the lan port of the zyxel and then the computer on the lan into the lan port on the 318n. By default, the 318n will allow traffic to pass to the zyxel which will in turn pass it on to the Internet. This should work without an issue.
All those rules and services may be the issue. By default, the netgear will pass ZERO traffic to your lan, so you're actually punching holes in the firewall rather than securing the device.
If you have remote management configured on the netgear and someone there who could physically make the cable changes, you can easily test without physically being there.
spaceobh
Oct 09, 2015Aspirant
SamirD wrote:Thank you for the diagrams as it makes it very clear. I wish others could do that in their threads!
Yep, a picture is always good
So normally (and probably your current setup), the zyxel is in place of the netgear in the diagram showing the computer on the lan, correct? If so, you can plug a *default configuration* 318n wan port into the lan port of the zyxel and then the computer on the lan into the lan port on the 318n. By default, the 318n will allow traffic to pass to the zyxel which will in turn pass it on to the Internet. This should work without an issue.
I hear what you are saying, but this make the 318 a simple hub, right?
Yeah, well, that was the intention, allow access for legal external IP adresses, and preventing unwanted.
I did that too, before I threw the towel, but after the futile attemtps to make the 318 forward the LAN/NAT/WAN-IP of the transmitting unit, I re-inserted the Zyxel.
The local hands are not able to fiddle with the 318, and since it's voluntary aid I don't want to exhaust my goodwill on an activity that will take a rather long time (already have) with little chance of success.
I may even consider getting another make unit for installation at the site.
Thanks for your contributions :smileyhappy:
