ticedoff8
Nov 23, 2020Aspirant
How to enable SSH on BR200 Firewall?
I have a new BR200 firewall (replaced an old ProSafe FVS318G). How do I enable SSH in the BR200? I've looked in all the GUI screens in Basic & Advanced and cannot find anything about enabling SSH
DaneA
Jan 05, 2021NETGEAR Employee Retired
As far as I have checked the BR200 user manual here, SSH is not mentioned. It is possible that SSH access is only for the higher tier of NETGEAR Support.
DaneA
NETGEAR Community Team
- ticedoff8Jan 05, 2021AspirantNETGEAR Moderator
"As far as I have checked the BR200 user manual here, SSH is not mentioned. It is possible that SSH access is only for the higher tier of NETGEAR Support."
Yes, I checked the manual too.
I have the WAC720 ProSafe wireless gateway that does have SSH and that is the only way I could dig myself out of the hole that was created when I upgraded its firmware and the new firmware did not support one of the "special" characters that I used in the password. Because it had SSH, I could PuTTY into the WAC720 using the old password and change it without having to start over again.
I would place the BR200 on the same tier as the WAC720 in terms of business class network devices.This seems like a omission by NETGEAR.
"SSH is not a feature on the BR200 unit as we do not allow internal access to the unit at this time."
Being that the BR200 is relatively new, is anything on the roadmap for future releases of firmware that will enable / include SSH to the BR200?- schumakuJan 05, 2021Guru - Experienced User
The WAC720/730 has a more or less unofficial CLI (not a Linux shell) accessible by SSH.
The BR200 does not have a CLI, so no need to open up an SSH access. For the unlucky password situation (caused by a late spec change i guess), a factory reset would have resolved the issue, too.
"The WAC720/730 has a more or less unofficial CLI (not a Linux shell) accessible by SSH.
The BR200 does not have a CLI, so no need to open up an SSH access. For the unlucky password situation (caused by a late spec change i guess), a factory reset would have resolved the issue, too."
The WAC720 has a serial port - that is how I was able to log in and change the password because I had not previously enabled the SSH log-in. But, the serial port saved me. Because there is a serial port, the CLI on the WAC720 is not "unofficial" - it is built-in.
The ProSAFE FVS318G Firewall has a serial port too. And, the CLI was better than it's GUI. The GUI on the FVS318G was basically a lame GUI-adaptation of the CLI. I replaced the FVS318G with the BR200 because the FVS318G was only getting 30Mb/S on a 100Mb/S ISP uplink even though the FVS318G has all 1GbE ports (design limitations). I didn’t notice the BR200 didn’t have a serial port until I took it out of the box.
While the BR200 doesn't have a CLI today, it definitely needs one.
Suggesting a CLI is not needed in the BR200 is like suggesting that Cisco / Arista / Juniper products don't need a CLI. There is more to configuration, debugging and password recovery than a GUI can provide.
At least the BR200 is getting better throughput than the FVS318G.
- MrJoshWJan 05, 2021NETGEAR Employee Retired
We do plan to make improvements to the BR200, but cannot confirm what features are in the pipeline for this product. Be sure to be on the lookout for any updates to the BR200 in the near future.
