cosac
Nov 06, 2015Aspirant
Ideas for new guest network
Hi All, Currently we have a Netgear Firewall FVS336G and a Netgear Prosafe Switch JGS524E, we have two ISPs and use both WAN ports on the firewall. We would create a separate network, with th...
JohnRo
Nov 06, 2015NETGEAR Employee Retired
Hello cosac,
Welcome to the community!
There is a feature on the FVS336G that might be able to accomplish what you are looking for. Please check the reference manual, see page 129 (Manage IPv4 Multihome LAN IP Addresses on the Default VLAN).
If you have more questions, the community is happy to help.
Thanks,
- cosacNov 09, 2015Aspirant
Hello JohnRo,
Thanks for the input, but I think this solution is not suitable for us, because it is not DHCP capable as manual says:
"You cannot configure secondary IP addresses in the DHCP server. For the hosts on the secondary subnets, you must manually configure the IP addresses, gateway IP address, and DNS server IP addresses."
I think a FVS318G or FVS318N could be enough for our needs in one single product.
Thanks and regards,
Cristian
