mike1110
Jul 22, 2026Tutor
Inter VLAN Traffic open between Multi-PSK SSID Connected VLANS - BUG
Hello, I run a PR60X via Insight, and have five vlans. My Core Switch is the MS510TXUP and intervlan routing as far as I am aware is done on the PR60X. When I log on directly to the MS510TXUP, it...
whispy64drown
Aug 10, 2026Aspirant
Hello,
This looks like a significant issue with how Multi-PSK VLAN traffic is being handled. The fact that the Guest SSID appears to have an implicit deny while the Multi-PSK networks can reach all VLANs is especially concerning. I’d also like to know whether this behavior is documented or expected. A clear catch-all inter-VLAN deny rule that doesn’t accidentally block the router’s own VLAN interfaces would be extremely useful. Hopefully Netgear can clarify the intended behavior and provide a recommended rule configuration.
Best Regards
