mike1110
Jul 22, 2026Tutor
Inter VLAN Traffic open between Multi-PSK SSID Connected VLANS - BUG
Hello, I run a PR60X via Insight, and have five vlans. My Core Switch is the MS510TXUP and intervlan routing as far as I am aware is done on the PR60X. When I log on directly to the MS510TXUP, it...
gene22dony
Aug 14, 2026Aspirant
This sounds like a significant security concern, especially since the Multi-PSK SSID appears to bypass the expected inter-VLAN restrictions and exposes more networks than the VLANs assigned to the SSID. The difference in behavior between Multi-PSK and the Guest SSID definitely deserves clarification from Netgear. An explicit catch-all deny rule for inter-VLAN traffic, with specific allow rules taking precedence, would be a much cleaner and safer solution than creating 5×5 rules. Hopefully Netgear can confirm whether this is intended behavior or a bug and provide documented guidance for properly isolating these VLANs.
