RoadieMatt
Nov 26, 2014Aspirant
Internet access issues between the IAP-103 & FVS336Gv2
Currently I have a FVS336Gv2 installed as my main router, running Firmware Version 4.3.1-18, and setup with 3 Vlans each with their own DHCP. This then goes to my Aurba IAP-103 which is tagged to each...
RoadieMatt
Nov 28, 2014Aspirant
For the Question:
1. the AP is connected the following way, As well the AP has a static IP address and the static IP is tagged under Vlan 1
AP > JGS516PE > FVS (AP is getting PoE from the JGS)
2. DHCP Lease time
Vlan 1 - 72hours (non guest office use only
Vlan 2 - 1hr guest WiFi
Vlan 3 - 1hr guest Wifi / Demo phone
3. when this happens all wired connections have no issue including the AP, I can still see and access AP from the wired side and WiFi side if on a client that already connected. As well any pre authorized and WiFi users with a current DHCP lease have no issues
Other questions:
1.A computer or a phone will not fully connect when this issues happens. But on the APs GUI I can see units connecting the AP. They will not get any kind of IP address and on the APs GUI it will be listed as 0.0.0.0
2. Aruba is assigned a static IP address
2. DHCP Lease time
Other questions:
