oldyoungguy
Jun 08, 2016Aspirant
IPSec VPN client for FVS318 ProSafe
I am trying to setup a home vpn for my ocassionally trips. For the IPSec VPN client, is there any openSource software I can use with the FVS318 ProfSafe? Thanks, James
oldyoungguy
Jun 09, 2016Aspirant
Hi Danthem,
Thank you for your help.
I think we are very close to the target now.
This is the FVS318 VPN settings. I only added Local IPSec Identifier and Remote IPSec Identifier. All others are from the VPN Wizard.
In the VPN client, only the following two are not follow your instruction: I selected the Key Identifier as the Identification Type.
Hope you can find something wrong on these settings.
Thanks,
James
oldyoungguy
Jun 10, 2016Aspirant
In the VPN Settings, I also tried the Agressive in the Secure Association entry.
- DanthemJun 10, 2016NETGEAR Employee Retired
Hey, your two first images were not approved so I can't see them.. Did they contain senstive data? Make sure to censor any sensitive data before posting it here.. You can also PM me instead if you want.
cheers,
Danthem
- oldyoungguyJun 10, 2016Aspirant
I crossed my ip address and try again.
