kdseth's avatar
kdseth
Follower
Jan 10, 2020
Is there a way to neutralized visitors from office PCs in netgear router fvs336gv2?
Hello! Is there a way to neutralized visitors from office PCs in netgear router fvs336gv2? I am using netgear router fvs336gv2, for office computers and also allowing visitors to browse through the router via a wifi conection. But I need help to configure the netgear router fvs336gv2 to divide and neutrlized the visitors from the office computers.Any Help? Thank you! Seth.
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    @kdseth,
    Here is a typical network setup that you need to implement:
    From the network diagram above, the modem is connected to the WAN 1 port of the FVS336Gv2 firewall router.  The FVS336Gv2 supports VLAN.  You will need to configure VLANs to segregate networks.  You need to separate the Private (or Admin) network from the Guest network.  A LAN port of the FVS336Gv2 is connected to port 1 of the GC105PP smart switch.
    The GC105PP supports VLAN and PoE (Power over Ethernet).  Port 8 of the GC728XP is directly connected to the WAC510 access point.  Since the GC105PP supports PoE, it can power up the WAC510 through its ethernet port.  Be reminded that the WAC510 does not come with a power adapter that is why a PoE switch is needed to power it on.
    The ports connecting the GC105PP and the WAC510 should be configured as tagged ports because the WAC510 is a VLAN-aware device.  Since the WAC510 also supports VLAN, you can assign a wireless network dedicated to the Private network as well as assign a wireless network for the Guest network.  The WAC510 supports Facebook WiFi which you can implement to provide your guests with WiFi access by letting them check in to your company's Facebook business page through a captive portal assigned to the Guest Network.
    Let me share the article below:
    How do I set up one or more VLANs between a NETGEAR ProSAFE firewall and a smart switch?
    To know more about the GC105PP and WAC510, kindly access their respective data sheets below:
    GC510PP Data Sheet
    WAC510 Data Sheet
    Be informed that both GC105PP and WAC510 can be managed via NETGEAR Insight.  To know more about Insight, visit the links below:
    Insight by NETGEAR
    Insight Management Solution
    Furthermore, you can check other Insight Managed Smart Cloud Switches here and you can check other Insight Managed Access Points here
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
