hmg21215
Dec 04, 2017Aspirant
Is there something like fail2ban for teh FVS336Gv3?
We run an asterisk PBX behind the FVS336Gv3. We have remote users who need to connect to the pbx, so SIP traffic is routed through the FVS336Gv3 to the PBX. There are lots of scanners out there that ...
hmg21215
Dec 05, 2017Aspirant
Dane,
Thanks for your responce. I should have mentioned in my original post that I have made these rules manually, but as soon as I block on IP or group of IPs, another one pops up. So what I really would like to do is to have a dynamic inbound rule, that kicks in on any IP according to parameters that I would set, for instance twenty attempts within five seconds. The ban could either expire after a set period of time, like an hour, or I could clear it out every week or so. Do you know of any way to do that?
Thanks
DaneA
Dec 05, 2017NETGEAR Employee Retired
It seems that there is no option on the FVS336Gv3 settings to configure exactly the way you have described. Kindly try the following:
1. On the web-GUI of the FVS336Gv3, go to Security > Firewall > Attack Checks. Check the following boxes: Enable Stealth Mode, Block TCP Flood and Block UDP Flood. As reference, kindly read pages 268-270 of the FVS336Gv3 reference manual here about Manage Protection Against Common Network Attacks.
2. On the web-GUI of the FVS336Gv3, go to Security > Firewall > Session Limit. Then, set the liimits for IPv4 Sessions. As reference, kindly read pages 274-276 of the FVS336Gv3 reference manual here about Set Limits for IPv4 Sessions.
DaneA
NETGEAR Community Team
