jcdole
Feb 09, 2019Tutor
Lan Groups "Known PCs and Devices" - Setting a name
Hello.
In /Network Configuration/Lan Setup/Lan Groups/Known PCs and Devices
Is it possible to set a name for a known mac address without reserving an IP address for it
Example : "unknown* 192.1...
jcdole
Feb 14, 2019Tutor
Thank you
DaneA
Feb 14, 2019NETGEAR Employee Retired
You're welcome! :) If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
